Введение
If the DPI (dots per inch) sensor inside your Corsair Katar mouse is not operating correctly, this guide will show you how to replace it.
Выберете то, что вам нужно
Remove the three skates on the bottom of the mouse using the plastic opening tools.
Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
Detach the bottom of the mouse from the upper shell.
Use the plastic opening tool to detach the white DPI sensor cable from its port.
Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor.
2 участников успешно повторили данное руководство.
