Введение
If you need to disassemble your Corsair Katar mouse, this guide will demonstrate how to take it apart.
Выберете то, что вам нужно
Remove the three skates on the bottom of the mouse using the plastic opening tools.
Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
Detach the bottom of the mouse from the upper shell.
Use the plastic opening tool to detach the white DPI sensor cable from its port.
3 участников успешно повторили данное руководство.
