Введение
If the attached USB cable on your Corsair Katar mouse is not working due to damage or exposed wires, this guide will show how to replace it.
Выберете то, что вам нужно
Remove the three skates on the bottom of the mouse using the plastic opening tools.
Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
Detach the bottom of the mouse from the upper shell.
Use the plastic opening tool to detach the white DPI sensor cable from its port.
Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
Use the plastic opening tool to pry the white cable jack away from the motherboard.
Lift the motherboard away from the bottom of the mouse.
Use the JIS 0 screwdriver to remove the 5mm screw attached to the USB wire housing.
Lift the USB wire away from the shell of the mouse.
Еще один человек закончил это руководство.
