Введение
Eventually, the battery for the Corsair headphones will need to be replaced. Luckily, replacing the battery is a relatively simple process that involves removing the panel covering an earmuff and unplugging the old battery.
Instructions for removing the battery all refer to the right hand earmuff.
Выберете то, что вам нужно
Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
14 участников успешно повторили данное руководство.
13 Комментариев
Someone knows where to find the charging connector for the headset or can it be changed for usb-c?
It can be charge with any other USB mini/micro cable like the one for android phones, prior to USB-C
Unless your model of headset only allows USB-C then yes use any USB-C
Can someone please add a link to where you can buy this replacement battery - I would like to order a few.
So the battery that I ordered from here is a 700mAh. The on that I ordered from the link here is an 700mAh. Time to send this back and shop again
