Введение
Overtime, earmuffs for headphones need to be replaced. Follow these simple steps to learn how to replace your earmuffs. If you plan to replace the earmuffs, a replacement can be found form the Corsair site. It is also important to know how to disassemble the earmuffs in order to do most replacements or repairs for the headphones.
Выберете то, что вам нужно
Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
3 участников успешно повторили данное руководство.
