Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
All parts disassembled. Second photo shows back side of the PCB.
As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
A Telechips TCC771L as main CPU.
A PCF50606HN battery/power management chip.
3 Комментариев
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
