Введение
Often times it is only necessary to replace the carbon brushes, not the motor. Carbon brushes experience a lot of friction, and replacement is generally expected over time. Ensure your saw is unplugged before beginning the repair
Выберете то, что вам нужно
Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
After the washers are removed, gently grab the old brushes and remove them from the motor.
