Введение
The table guard is essential in making sure the Craftsman Model 315.10721 makes the desired cuts. Keep in mind when performing the replacement that disassembling the table guard is time consuming.
Выберете то, что вам нужно
Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
Pivot the table guard from its upright position to an angle.
Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
Carefully remove the main case to expose the inside of the saw.
Еще один человек закончил это руководство.
2 Комментариев
Where can I get a replacement table guard???
Where can I get a replacement table guard for this jig saw????????
