Craig CMP801 Front and Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: шаг 1, изображение 1 из 2 Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Front and Rear Facing Camera Replacement: шаг 2, изображение 1 из 2 Craig CMP801 Front and Rear Facing Camera Replacement: шаг 2, изображение 2 из 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Front and Rear Facing Camera Replacement: шаг 3, изображение 1 из 2 Craig CMP801 Front and Rear Facing Camera Replacement: шаг 3, изображение 2 из 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: шаг 4, изображение 1 из 2 Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: шаг 4, изображение 2 из 2
    • Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
  5. Craig CMP801 Front and Rear Facing Camera Replacement: шаг 5, изображение 1 из 1
    • Near the edge of the device, lift up the tab connected to the front-facing camera.
  6. Craig CMP801 Front and Rear Facing Camera Replacement: шаг 6, изображение 1 из 2 Craig CMP801 Front and Rear Facing Camera Replacement: шаг 6, изображение 2 из 2
    • Locate the black flap that covers and holds down the tab connected to the rear-facing camera.
    • Flip the flap up to release the tab.
  7. Craig CMP801 Front and Rear Facing Camera Replacement: шаг 7, изображение 1 из 2 Craig CMP801 Front and Rear Facing Camera Replacement: шаг 7, изображение 2 из 2
    • Gently pull on the tab connected to the front-facing camera to release both the front and rear-facing cameras.
Заключение
Еще один человек закончил это руководство.
Erin
Участник с: 09/25/17
117 Репутация
1 руководство автора
Команда
University of North Texas, Team S2-G2, Thompson Fall 2017 Участник University of North Texas, Team S2-G2, Thompson Fall 2017
UNT-THOMPSON-F17S2G2
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 246
