Введение
This guide will walk you through the process of replacing the broken front or rear facing camera of a Craig CMP801.
Выберете то, что вам нужно
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
Use a metal spudger to separate the back cover from the front touch screen.
To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
Continue to separate all of the clips around the device until the back cover comes off completely.
Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
Near the edge of the device, lift up the tab connected to the front-facing camera.
Locate the black flap that covers and holds down the tab connected to the rear-facing camera.
Flip the flap up to release the tab.
Gently pull on the tab connected to the front-facing camera to release both the front and rear-facing cameras.
Еще один человек закончил это руководство.
