Введение
This guide will provide instructions on how to upgrade or replace the hot end nozzle on a Creality Ender 3 Pro (2022). A broken or clogged nozzle will often lead to printing errors, which wastes both time and filament.
Выберете то, что вам нужно
Press the knob to enter the Ender 3 Pro menu.
Turn the knob to navigate to the temperature menu.
Click on the nozzle setting found in the temperature menu.
Turn the knob to set the nozzle to 200 C.
Depress the extruder spring using the handle.
Pull the filament from the extruder, while keeping constant pressure on the extruder spring.
Unscrew the two screws holding the fan shroud in place using the proper Allen key.
Place the new nozzle within the 7mm socket wrench.
Grab the hotend using the adjustable wrench as seen in step 7.
Screw in the new nozzle again using the 7mm socket wrench.
Reattach the fan shroud by screwing in the two screws.
Place the silicon sock back on the hot end, avoiding contact with the metal.
Navigate back to the temperature menu.
Set the nozzle temperature to 0 C, allowing it to cool down fully.
