Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
Детали не указаны.
  1. Using your thumb, slide down and remove the battery cover.
    • Using your thumb, slide down and remove the battery cover.
  2. Using your index finger, remove the old AA battery.
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
  3. Slide down the eject button.
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
  4. Using a Phillips #00 Screwdriver, remove the two 7.5 mm screws located on the left and right side of the back cover, respectively.
    • Using a Phillips #00 Screwdriver, remove the two 7.5 mm screws located on the left and right side of the back cover, respectively.
  5. Remove the back cover of the Nomad II.
    • Remove the back cover of the Nomad II.
    • Remove the following items located on the left and right side of the device:
    • The rubber USB port cover
    • The plastic lock/unlock switch cover
    • The buttons located on the left side of the device
  6. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  7. Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located in the bottom corners of the battery compartment.
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located in the bottom corners of the battery compartment.
  8. Using your fingers, carefully remove the battery compartment.
    • Using your fingers, carefully remove the battery compartment.
  9. Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located on the left and right edges of the circuit board.
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located on the left and right edges of the circuit board.
  10. Using a pair of tweezers, carefully remove the metal loop attached to the circuit board from its plastic case on the left side of the battery compartment.
    • Using a pair of tweezers, carefully remove the metal loop attached to the circuit board from its plastic case on the left side of the battery compartment.
  11. Pull out the circuit boards.
    • Pull out the circuit boards.
    • When reinserting the circuit boards, press the front face of the boards into the device case until you hear a click.
  12. Position the circuit boards with the USB port facing up.
    • Position the circuit boards with the USB port facing up.
    • Gently separate the circuit boards.
  13. Using a pair of tweezers, gently lift and peel back the thin copper film covering the headphone jack.
    • Using a pair of tweezers, gently lift and peel back the thin copper film covering the headphone jack.
    • Only peel back the film enough to expose the headphone jack.
    • Completely removing the copper film can damage the device.
  14. Gently remove the black adhesive tape from the underside of the headphone jack.
    • Gently remove the black adhesive tape from the underside of the headphone jack.
  15. Desolder the four solder joints securing the headphone jack.
    • Desolder the four solder joints securing the headphone jack.
    • Remove the old headphone jack.
    • Install the new headphone jack.
Заключение
Craig Fischer
Участник с: 24.01.2012
21 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-2, Regan Winter 2012 Участник Cal Poly, Team 9-2, Regan Winter 2012
CPSU-REGAN-W12S9G2
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,431
