Creative Zen Microphoto Screen Replacement
Выберете то, что вам нужно
  1. Creative Zen Microphoto Screen Replacement, Sliding Off the Back Cover: шаг 1, изображение 1 из 1
    • Slide off the back cover to reveal the battery.
  2. Creative Zen Microphoto Screen Replacement, Removing the Battery: шаг 2, изображение 1 из 1
    • Removal of the battery may require some force.
    • Beginning with the notch directly beneath the battery, use the plastic opening tool to loosen the battery.
    • Once the battery is free, remove it from the device.
  3. Creative Zen Microphoto Screen Replacement, Separating the Front Cover: шаг 3, изображение 1 из 1
    • Turn over the device.
    • Use the plastic opening tool to separate the front and back covers.
    • Move the opening tool around the perimeter of the device until the front cover detaches.
  4. Creative Zen Microphoto Screen Replacement, Removing the Front Cover/Keypad: шаг 4, изображение 1 из 1
    • Slowly detach the front cover from the rest of the device to reveal the interior.
  5. Creative Zen Microphoto Screen Replacement, Disassembling the Internal Device: шаг 5, изображение 1 из 1
    • Insert the flat-head screwdriver into the notch on the bottom of the device. Pry the main board and screen from the outer shell of the device.
  6. Creative Zen Microphoto Screen Replacement, Removing the Main Board and Screen from the Device: шаг 6, изображение 1 из 1
    • The power button will come loose upon removal of outer shell. When reassembling, align power button properly.
    • Remove the main board and screen from the outer shell.
  7. Creative Zen Microphoto Screen Replacement, Taking off the Back Cover of the Main Board: шаг 7, изображение 1 из 2 Creative Zen Microphoto Screen Replacement, Taking off the Back Cover of the Main Board: шаг 7, изображение 2 из 2
    • No tools are needed. The prongs (pictured) will release easily to remove the back cover.
    • Carefully remove the back cover.
  8. Creative Zen Microphoto Screen Replacement, Removing the Main Board from the Screen: шаг 8, изображение 1 из 1
    • Be gentle when removing the main board. The main board is attached to the front panel of the device by wires.
    • Using the flat-head screwdriver, carefully pry open the prongs on the sides of the device, and remove the main board from the screen.
  9. Creative Zen Microphoto Screen Replacement, Removing the Main Board from the Device: шаг 9, изображение 1 из 3 Creative Zen Microphoto Screen Replacement, Removing the Main Board from the Device: шаг 9, изображение 2 из 3 Creative Zen Microphoto Screen Replacement, Removing the Main Board from the Device: шаг 9, изображение 3 из 3
    • Do not damage the ribbon tab (pictured). It is vital to the device.
    • Push the ribbon tab (sticking out below the main screen) backward through the square hole to remove the main board of the device.
    • Once the wiring is removed from the front panel, release the hinge at the bottom of the device. To do so, gently pry underneath the clip (pictured) with a plastic opening tool. The clip will pop up, and the motherboard can be completely removed.
  10. Creative Zen Microphoto Screen Replacement, Removing the Bottom Blue Rubber Cover: шаг 10, изображение 1 из 1
    • With a set of tweezers, Carefully pull off the the bottom blue cover and remove it from the 8 GB hard drive.
    • DO NOT REMOVE THE TOP BLUE RUBBER COVER.
  11. Creative Zen Microphoto Screen Replacement, Removing the Screws from the Screen: шаг 11, изображение 1 из 1
    • Using a screwdriver, remove four Philip screws from the back of the screen.
    • Place the four screws in a small baggy for later reassembly.
  12. Creative Zen Microphoto Screen Replacement, Detaching the Hard Drive from the Main Board: шаг 12, изображение 1 из 1
    • Carefully pull out the gold piece from the top of the hard drive.
  13. Creative Zen Microphoto Screen Replacement, Removing the Screen from the Device: шаг 13, изображение 1 из 2 Creative Zen Microphoto Screen Replacement, Removing the Screen from the Device: шаг 13, изображение 2 из 2
    • Carefully use your thumbs to pull out the screen (that is below the hard drive).
  14. Creative Zen Microphoto Screen Replacement, Removing Black Adhesive Strip from the Screen: шаг 14, изображение 1 из 1
    • Look for a black strip on the side of the screen.
    • Remove the strip from the screen using your fingers or tweezers if needed.
  15. Creative Zen Microphoto Screen Replacement, Pulling Down the Red Strip of the Screen: шаг 15, изображение 1 из 1
    • With tweezers, lightly pull down on red strip in the middle of the back of the screen.
  16. Creative Zen Microphoto Screen Replacement, Detaching the Red Strip from the Back of the Screen: шаг 16, изображение 1 из 2 Creative Zen Microphoto Screen Replacement, Detaching the Red Strip from the Back of the Screen: шаг 16, изображение 2 из 2
    • With the tweezers, carefully pull the red strip off of the back of the screen.
    • DO NOT FULLY DETACH THE TAB FROM THE DEVICE.
  17. Creative Zen Microphoto Screen Replacement, Removing the Screen from the Device: шаг 17, изображение 1 из 2 Creative Zen Microphoto Screen Replacement, Removing the Screen from the Device: шаг 17, изображение 2 из 2
    • Carefully lift up the two pieces of the screen to reveal the actual back of the screen.
    • Pull out the screen from the device.
Заключение
3 участников успешно повторили данное руководство.
Emily Hill
Участник с: 09/30/14
146 Репутация
1 руководство автора
Команда
Ohio State, Team 1-3, Buehl Fall 2014 Участник Ohio State, Team 1-3, Buehl Fall 2014
OSU-BUEHL-F14S1G3
4 членов
Автор 2 руководств
7 Комментариев
Great way to destroy a Zen. Don’t pry the front off. Slide the metal cover under the battery down away from the contacts so that the tabs beside the battery contacts disengage, then press on the lower part of the battery compartment while holding the front. This keeps you from ripping the touch pad connector off and you can access everything with the front panel still glued on. Just proceed to remove the rear cover, then remove the motherboard, and you have access to the screen.
Nick Burtinsky - Ответить
Thank u very much.
Barbie Calzado -
I was just coming to comment this, I wish I had read the comments first. Along with not destroying the player, it's also so much easier. This seriously needs to be corrected.
ocddev -
Where can i buy a new screen for my zen microphoto?
Pedro Neves - Ответить
Seconded. Looking for a new screen. Anyone have any tips?
Cory Roberts -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 34
За всё время: 3,512
