Введение
The Creative Ziio boasts excellent sound quality and usability. It uses a 7'' LCD screen that cannot be replaced by a generic screen. Replacement screens may be provided by contacting Creative, depending on warranty details. Searching local tech stores or online tech supply sites may be helpful as well.
Выберете то, что вам нужно
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
Remove the four 3mm Philips #00 screws around the large silver battery.
Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
Carefully lift up the circuit board on the detached side.
Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
2 участников успешно повторили данное руководство.
2 Комментариев
Where can I buy Creative Ziio 7" LCD Scren?
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
