Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
In this guide, you will be able to remove the motherboard from a creative ZiiO and use a soldering iron while doing so.
Запчасти
Детали не указаны.
  1. Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges. The volume control button and the top power button may fall out during this step. The volume control button and the top power button may fall out during this step.
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Remove the copper plate covering the motherboard by desoldering the ten solder points. The solder point in the bottom right corner is marked but hidden by the soldering iron. The solder point in the bottom right corner is marked but hidden by the soldering iron.
    • Remove the copper plate covering the motherboard by desoldering the ten solder points.
    • The solder point in the bottom right corner is marked but hidden by the soldering iron.
  3. Remove the adhesive tape covering the three wires connected to the motherboard. Desolder the solder points connecting the wires to the motherboard.
    • Remove the adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the motherboard.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Disconnect the ribbon cable that is attached underneath the copper plate. Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board. Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
    • Disconnect the ribbon cable that is attached underneath the copper plate.
    • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
  6. Remove the four 4mm Philips #00 screws  holding the motherboard to the casing. The copper plate will be removed by now. However, the picture does not show this.
    • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
    • The copper plate will be removed by now. However, the picture does not show this.
  7. Lift up the motherboard. A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Lift up the motherboard.
    • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
  8. Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
  9. Remove the old motherboard and dispose of it resposibly.
    • Remove the old motherboard and dispose of it resposibly.
Заключение
2 участников успешно повторили данное руководство.
Benedict Samoy
Участник с: 16.04.2013
19 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 14-10, Maness Spring 2013 Участник Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 членов
Автор 13 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,126
