Введение
Перейти к шагу 1 ↓Follow this guide to replace the blade housing in your Cricut Maker 3.
If you want to use certain kinds of specialty blades, or if you blade is not rotating freely in the housing, you may need to replace the blade housing.
Open the Cricut by lifting the top silver lid. The front tray will also open.
Partially open clamp B on the tool holder by pulling the plastic latch away from the tool holder.
While holding the blade housing in the tool holder, fully open clamp B by pulling the plastic latch to the right.
Grab the blade housing by the top and remove it from the tool holder.
