Введение
In the event that the door of your Cricut Maker won't stay closed because it's damaged, it could be time for a replacement. Follow this step-by-step guide to change the lid on your own.
First make sure the connecting magnets are clear of debris, which may be preventing them from closing. If there are any obstructions, clear these away and the magnets should stick once again. However, in the event that there is no obstruction, perform a magnetic test on the lid magnet to the front door to determine if you need to replace the lid.
In step one, you must pry glue from plastic, so be gentle to avoid breaking or damaging the lid further.
Выберете то, что вам нужно
To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
Remove the cover from the connecting joint and set it aside.
Turn the device around, so that the back is facing you.
Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
These actions should reveal the cylindrical connectors.
Press down on the lid.
Push the lid outwards to free it from the jointed clasps.
3 участников успешно повторили данное руководство.
