Введение
The sealing ring allows the pot to pressurize and seal properly. A missing or damaged sealing ring can lead to device failure. Use this quick and easy replacement guide to fix any problems pertaining to the sealing ring in your Crock-Pot Express Crock Multi-Cooker.
Выберете то, что вам нужно
Remove the power cord from the wall outlet first, disconnecting power from the device.
Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
Grasp the power cord input connector firmly with forefinger and thumb.
Without tugging, apply pulling force until the connector is free from device
Orient the crock pot where the lid locked and unlocked icons are visible.
Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
Remove the lid.
Using a plastic opening tool, work your way in between the metal and sealing ring.
Continue to rotate and pry with the plastic opening tool until the sealing ring separates from the top.
I store my Crockpot Express Multicooker in the locked position. For some reason, it won’t lock. The sealing ring is properly installed. Can you help me - any ideas. Thanks.
I don't have a plastic opening tool
I put a new seal in, now it won't seal!
I have the same questions. Do you ever respond to comments? If not, this is a total waste.
I found a replacement on Amazon https://a.co/d/5sxu7bP for my 10 qt crock pot express. To make sure I had the right size gasket/ring, I first place the silicone ring over the edge of my pot where the lid goes. The middle part of the ring should sit perfectly on top of the pot. Mine did. YAY!
It was a very, very tight fit in the lid and since i did not have a plastic tool to help push it under the metal ring that holds it in place, I used the base of a thin table knife to put the presser on the ring as I pressed down on it at the same time. In the same manner the gentleman on the video was doing it to get it in. The gasket must go in so that the center lip sits on the lids inside edge or your lid will not close.
Tough job but it can be done.:)
2 участников успешно повторили данное руководство.
8 Комментариев
Thank you for giving me the answer to how to be sure I assemble the seal correctly in the Crock Pot Express after we clean the cooker after I unboxed it. A video should be included with the Crock pot Express , it wwould help a lot. There were no pictures of the underside of the lid. The placement of gasket is very crucial to safety. I used a pressure scanner years ago. Iam impressed with the E6 flashing on the control panel. I do like the cooker overall!
Thank you very much for the advice. Now I can make sure I am placing the gasket in the cooker correctly. I used a pressure scanner/ cooker 30years ago! I like the e6 warning which was on the control panel to let me know that the pressure was not building up. I was able to let the steam off.
This gasket / seal seems very loose and ill fitting. Is this normal?
I agree it falls off mine on it’s own
gestep -
Where do I find the question & response to gnag321 ?
I have same question as mark.e.betty. I seem to have the seal in in the only way it will fit. Please advise as I love this machine & want to a lot more cooking. Tks
Can't find the silicone seal for my mod. #sccppc804-v1 Crock Pot Pressure Cooker machine?
how many sealing rings does a crockpot express have
Hi, having trouble with sealing ring. Keeps falling off. Mine is not silicone but rubber. Does this make a difference?
