Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If the steam release valve is broken or damaged in any way it will not seal and can cause a safety hazard when trying to open a pressurized pot.
If replacement of the Steam Release Valve does not solve problem try replacing Steam Release Valve Cover.
Инструменты
Инструменты не указаны.
Запчасти
  1. Orient the crock pot where the lid locked and unlocked icons are visible. Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other. Remove the lid.
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  2. Orient the lid face up, allowing access to the steam release valve.
    • Orient the lid face up, allowing access to the steam release valve.
  3. Securely grasp the steam release valve and pull firmly perpendicular to the lid to remove the valve.
    • Securely grasp the steam release valve and pull firmly perpendicular to the lid to remove the valve.
    My release valve came off when I'm trying to clean and I put it back is that suppose to stay?or is really can come off?I'm scared to used it now.
    nicole09_oliva - Ответить
Заключение
Еще один человек закончил это руководство.
William Kelly
Участник с: 24.09.2018
718 Репутация
Автор 7 руководств
Комментариев: 6
Hi
I need to buy a replacement steam release valve for a Crock-Pot CPE200. I've contacted Sunbeam and they say you can't.
Any ideas?
shaz_44@yahoo.com
Sharon Miller - Ответить
I need a Steam Release Valve also would like some ideas since CrockPot does not let you order parts online anymore.Thinking about not using CP stuff no longer if replacement parts are going to be this hard to find! Linda Richardson lamommom50@yahoo.com.
lamommom50 - Ответить
If the steam release valve is broken and does not close all the way, will the pressure not build? Therefore not cooking correctly.
Katelyn Gerdik - Ответить
How do I get a replacement Steam Release Valve - mine no longer is attached to the Crock Pot, I think may have been dropped and now steam leaks from it right throughout the whole pressure cook operation. Can I purchase a new one through this site? andy.garlepp@live.com
Andy Garlepp - Ответить
Anyone know where I can get a .stl file to make a steam release valve cover on my 3D printer?
Please email me a link to pink192000@gmail.com if you find one. I've been searching for days.
Tosha Henderson - Ответить
Ok. So. My 10-qt Crockpot Pressure Cooker does build pressure. But the steam release valve doesn’t work. I have to let it naturally release pressure or use a chopstick to put the steam pin down in small spurts, as to not get burned.
What could be the cause of this?!
Is it fixable? How?
I use my p/c at least 3x a week and would love to get this fixed ASAP.
Thanks!
-Rebecca
rsc.1973@yahoo.com
Becca C. - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 33
За последние 30 дней: 180
За всё время: 6,978
