Введение
This guide will tell you how to replace the face of the Crosley 33301 alarm clock.
Выберете то, что вам нужно
Rotate Clock till the face/or front is pointing away from you.
Continue on by unscrewing the 5.5 millimeter screws with your hands.
Once all the screws are removed, take the circular back panel off and lay it down flat on a stable surface to put back on later.
You will notice that there are three small indents on alternate sides.
You will see small slits where the indents can slide through.
Twist the center counter clockwise so that the face and the back are no longer connected.
Replace the front of the clock with your new glass face protector and settle it on the frame.
Apply the clock face back on the frame, then reverse your steps. Take a step back and admire your handiwork!
2 участников успешно повторили данное руководство.
