Введение
This tutorial will provide the necessary information on how to replace a power cable in the Crosley CR42.
Выберете то, что вам нужно
Turn the device around until you are looking at the line-out port.
With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
Gently remove both wires.
After de-threading the antenna wire, remove the back of the device and set it aside.
Locate where the power cable connects to the device.
Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
Twist the connecting wires together.
Attach the twist-on wire connectors to the exposed wires.
Еще один человек закончил это руководство.
