Введение
When everything is working as it should, the speaker produces nearly the same vibrations that the microphone originally recorded and encoded on a tape, CD or LP record.
Выберете то, что вам нужно
Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
Gently remove the back panel of the device being careful not to unplug any internal wires.
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
Еще один человек закончил это руководство.
Один комментарий
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
