Введение
If the volume knob on your Crosley Cruiser (CR8005A) is cracked, damaged, or having trouble turning, this guide will show you how to safely remove and replace it. (You can also remove the knob if you just want to inspect, clean, or customize it.)
The only tool required is a plastic opening tool or spudger.
Выберете то, что вам нужно
Make sure that the power is off.
Turn the volume knob counterclockwise as far as possible.
Unplug the power cord.
The power light should be off. If the light is glowing red, wait until the light goes out.
To put the knob back on, push the knob directly down onto its peg.
Еще один человек закончил это руководство.
2 Комментариев
Hi, how to change the actual know (not the plastic cover)?
As mine is faulty and I could use some help please haha
Digi-key part # similar to PTD908-1215K-B203-ND.
