Введение
This guide will explain how to replace Cuisinart CPT-140BK toaster circuit board. It instructs through the process of disassembly to prevent damage on display cables and panels.
Выберете то, что вам нужно
Turn the toaster upside down.
Unscrew all 4mm screws using Phillips #2 screwdriver.
Turn the toaster right side up.
Pull out the toaster lever knobs by pulling it away from the toaster before removing the top cover.
Detach the cable that connects the toaster to the circuit board, in both control panels.
Unscrew total of six 4mm screws that attach each circuit board to the top cover, using Phillips #2 screwdriver.
Remove and replace the circuit board.
