Введение
This guide will show you how to replace the display and will require soldering.
Выберете то, что вам нужно
Open the lid of the coffee pot.
Remove the two 1.6mm Phillips #1 screws from inside of the lid.
Slide the display into the coffee maker so that way you can access the screws in the back.
Remove the four 1mm Phillips #0 screws from the back of the display.
Remove the back panel from the display.
Remove the 1mm Phillips #0 screw from the motherboard.
2 участников успешно повторили данное руководство.
