Введение
This guide will show you how to remove the buttons on your food processor and replace them if they are damaged. This guide only requires the use of a screwdriver and nut driver, but gives you a look at the inside of your food processor.
Выберете то, что вам нужно
Position the handle of the bowl so that it is on your left.
Grab the handle and push clockwise. Lift up the bowl to remove it.
Turn the food processor's base upside down by lifting it up and turning it over.
Position the base so that the on and pulse buttons are facing you.
Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
Slide off the switch and yellow plastic to remove the button assembly.
Еще один человек закончил это руководство.
