Введение
If your Cuisinart DGB-650 water pipes are having issues, such as leaking, you will gain access to the pipes with this simple guide. Make sure your device is unplugged to avoid any potential shocking.
Выберете то, что вам нужно
Turn the coffee maker upside down.
Remove the four 1.2 mm screws using a Phillips #0 screwdriver.
Remove the bottom cover to expose the heating element and motherboard.
Firmly grasp both pipe endings next to the motherboard and gently pull both ends out.
Remove the two 1.2 mm screws keeping the pipe clamp attached using a Phillips #0 screwdriver.
Lift the pipe clamp up and set it aside.
After heating the iOpener, wrap it around the ends of the orange tubes to help loosen the glued material.
Wedge the metal spudger between the metal and the tube.
Shimmy the spudger around the entire tube until the tube is loosened and can be pulled off.
Repeat the process with the other orange tube still connected.
Еще один человек закончил это руководство.
