Введение
This guide teaches the user how to replace the power cable in your Cuisinart DLC-8F. The removal of the power cable first requires the removal of the bottom hood and all of this can be done with just a Phillips #2 screwdriver. This is an easy process and should only take about 10 minutes.
Выберете то, что вам нужно
Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
2 участников успешно повторили данное руководство.
Один комментарий
So you pull apart the wires of the power cable and then what? Instructions seem incomplete.
