Введение
This guide teaches the user how to replace the safety switch in your Cuisinart DLC-8F. The removal of the safety switch first requires the removal of the bottom hood and all of this can be done with just a Phillips #2 screwdriver. This is an easy process and should only take about 10 minutes.
Выберете то, что вам нужно
Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
Remove the two 19 mm Phillips #2 screws holding the safety switch in the bracket.
Pull off the three wires on the safety switch with your hand by firmly grabbing the wires at the base.
2 участников успешно повторили данное руководство.
Один комментарий
how do you overrid the safty switch? What wires do you connect?
