Введение
Are you having issues with your Cuisinart Oven's light not turning on? You may need to replace the light's spring. This guide will show you how to.
Be warned, the light switch has small pieces.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
Pull off the back.
Pick the grey stoppers out with a sprudger.
Using a Phillips #1 screwdriver, remove these three 11 mm screws.
Почти готово!
Заключение
