Введение
To remove the disc tray bracket, you must first remove the top panel of the DVD, which exposes the disc tray bracket. The Disc tray bracket sits on top of the disc tray to keep the disc in place while in use.
Выберете то, что вам нужно
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Remove the top panel of the DVD Player by:
Sliding the top panel backwards.
Gently lifting the back of the top panel up.
Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
Lift up on the bracket by:
Sliding the disc tray bracket forward.
Lifting the back edge up.
3 участников успешно повторили данное руководство.
