Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
To remove the disc tray bracket, you must first remove the top panel of the DVD, which exposes the disc tray bracket. The Disc tray bracket sits on top of the disc tray to keep the disc in place while in use.
Запчасти
Детали не указаны.
  1. Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD. Unplug the DVD player from the wall socket.
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. Remove the top panel of the DVD Player by: Sliding the top panel backwards.
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray. Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
    • Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
  4. Lift up on the bracket by: Sliding the disc tray bracket forward.
    • Lift up on the bracket by:
    • Sliding the disc tray bracket forward.
    • Lifting the back edge up.
Заключение
2 участников успешно повторили данное руководство.
Chris Menezes
Участник с: 07.04.2014
630 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 6-5, Forte Spring 2014 Участник Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 33
За всё время: 3,285
