Введение
Replacing the disk tray requires you to first remove the top and back panels of the DVD player, locate the black disk tray, and slide away the disk tray
Выберете то, что вам нужно
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Remove the top panel of the DVD Player by:
Sliding the top panel backwards.
Gently lifting the back of the top panel up.
Remove the back panel by:
Lifting up on the back panel.
Pulling the back panel backwards from the DVD player.
Orient the device so the front is facing towards you. Remove the disc tray faceplate by lifting up on both corners firmly.
Detach the ribbon cable from the side of the DVD player by gently pulling it out.
Orient the device so the back is facing towards you. Remove the disk tray out towards the back of the DVD player by lifting it.
Еще один человек закончил это руководство.
