Введение
Replacing the disk tray requires you to first remove the top and back panels of the DVD player, locate the black disk tray, and slide away the disk tray
Запчасти
No parts specified.
  1. Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD. Unplug the DVD player from the wall socket.
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. Remove the top panel of the DVD Player by: Sliding the top panel backwards.
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. Remove the remaining screws on the back of the DVD player: There will be four 15 mm screws and two 6.3 mm screws.
    • Remove the remaining screws on the back of the DVD player:
    • There will be four 15 mm screws and two 6.3 mm screws.
  4. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  5. Remove the back panel by:
    • Remove the back panel by:
    • Lifting up on the back panel.
    • Pulling the back panel backwards from the DVD player.
  6. Remove the four 8.1mm screws in each of the corners of the disc tray. Remove the four 8.1mm screws in each of the corners of the disc tray. Remove the four 8.1mm screws in each of the corners of the disc tray.
    • Remove the four 8.1mm screws in each of the corners of the disc tray.
  7. Orient the device so the front is facing towards you. Remove the disc tray faceplate by lifting up on both corners firmly. The faceplate is located on the front of the DVD player and will prevent the disc tray removal if not removed.
    • Orient the device so the front is facing towards you. Remove the disc tray faceplate by lifting up on both corners firmly.
    • The faceplate is located on the front of the DVD player and will prevent the disc tray removal if not removed.
  8. Detach the ribbon cable from the side of the DVD player by gently pulling it out. Detach the ribbon cable from the side of the DVD player by gently pulling it out.
    • Detach the ribbon cable from the side of the DVD player by gently pulling it out.
  9. Orient the device so the back is facing towards you. Remove the disk tray out towards the back of the DVD player by lifting it.
    • Orient the device so the back is facing towards you. Remove the disk tray out towards the back of the DVD player by lifting it.
Заключение
Chris Menezes
Участник с: 07.04.2014
626 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 6-5, Forte Spring 2014 Member of Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 членов
Автор 5 руководств
Один комментарий
Bom dia. gostaria de obter informação sobre a referência desse componente CI u7 da placa ficarei muito grato
Gilvando - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 7
За всё время: 1,068
