Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Remove the top panel of the DVD Player by:
Sliding the top panel backwards.
Gently lifting the back of the top panel up.
Remove the remaining screws on the back of the DVD player:
Remove the back panel by:
Lifting up on the back panel.
Pulling the back panel backwards from the DVD player.
Remove the four 8.1mm screws in each of the corners of the disc tray.
Orient the device so the front is facing towards you. Remove the disc tray faceplate by lifting up on both corners firmly.
Detach the ribbon cable from the side of the DVD player by gently pulling it out.
Orient the device so the back is facing towards you. Remove the disk tray out towards the back of the DVD player by lifting it.
Еще один человек закончил это руководство.
