CyberHome CH-DVD 300 Power Supply Replacement
Выберете то, что вам нужно
  1. CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: шаг 1, изображение 1 из 2 CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: шаг 1, изображение 2 из 2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Power Supply Replacement: шаг 2, изображение 1 из 2 CyberHome CH-DVD 300 Power Supply Replacement: шаг 2, изображение 2 из 2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: шаг 3, изображение 1 из 3 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: шаг 3, изображение 2 из 3 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: шаг 3, изображение 3 из 3
    • Orient the device to locate the power supply board on the far right corner. Use needle nose pliers to pull the white connector from the power supply board.
    • The power supply board is connected directly to the power cord. This is not the same thing as the mother board.
Заключение
3 участников успешно повторили данное руководство.
Chris Menezes
Участник с: 04/07/14
654 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 6-5, Forte Spring 2014 Участник Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 членов
Автор 5 руководств
8 Комментариев
Mine had a bad 2200uf 10v capacitor… I replaced it and the player works fine.
Robert Brackett - Ответить
What and where is that located please?
Kealani Rowe -
So what capacitor have u replaced ?
semyonaxelrod -
I need another power supply board. Mine has 4 blown Capacitors and do not know if any resisters or diodes or small capacitors are bad because I have now testing tools to check them. Just what I see with eyes. Am a retired electronics professional (79) and know what I am doing. Please let me know if I can get a power supply board and the cost. Thank You .
Glennie Waters - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 17
За всё время: 3,988
