Выберете то, что вам нужно
Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
Detach the speaker wire by gently pulling on the side closest to the body of the camera.
2 участников успешно повторили данное руководство.
