D-Link EBR-2310 LED Light Replacement
Выберете то, что вам нужно
  1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: шаг 1, изображение 1 из 1
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 LED Light Replacement, Remove Screws: шаг 2, изображение 1 из 1
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: шаг 3, изображение 1 из 1
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: шаг 4, изображение 1 из 2 D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: шаг 4, изображение 2 из 2
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: шаг 5, изображение 1 из 2 D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: шаг 5, изображение 2 из 2
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: шаг 6, изображение 1 из 1
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
  7. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: шаг 7, изображение 1 из 1
    • Locate the problematic LED light on the motherboard.
    • Using a plastic opening tool, very gently tilt its black base backwards.
  8. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: шаг 8, изображение 1 из 2 D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: шаг 8, изображение 2 из 2
    • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
  9. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: шаг 9, изображение 1 из 1
    • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
  10. D-Link EBR-2310 LED Light Replacement, Complete Removal: шаг 10, изображение 1 из 1
    • You should now have a removed LED light, ready to be replaced with a new one.
Заключение
Jessica
Участник с: 09/19/14
428 Репутация
Автор 3 руководств
Команда
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Участник USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 членов
Автор 19 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 353
