Введение
The fan removes warm air from the inside of the projector. If the fan is not working correctly, the projector could overheat and damage could occur.
This guide can also help to keep the fan clean from dust and dirt to prevent overheating.
Выберете то, что вам нужно
Place the projector upside down to access the screws on the bottom.
Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
Remove the three 6mm PH2 phillips head screws.
Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
Lift the motherboard up and place it out of the way.
Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
Lift the aluminum heat sink up to remove it from the projector.
Еще один человек закончил это руководство.
2 Комментариев
Wich cooler does fit ? I just bought the Projector and want to change the Fan because it is too loud
