Введение
This tutorial will show you how to prepare your DJI Mavic Mini drone for flight and connect it to the remote control.
Have fun!
Turn the rotor blades towards the battery compartment.
Grasp the cover tab with one finger, gently push it towards the camera and remove the cover.
Hold the drone with one hand and unfold the rotor arm with the other.
Repeat the process on the other side.
Turn the drone onto its back.
Fold out the rotor arm in an arc towards the battery compartment.
Repeat the process for the other rotor arm.
Stecke dein Handy in die Halterung und verbinde es per Kabel mit der Fernbedienung.Put your phone in the cradle and connect it to the remote control via cable.
Press the On button once briefly, release it, and then press and hold until you hear a "beep" sound.
Press the button on the bottom once briefly, let go, and then hold it down until you hear a "beep". (similar to the remote control).
Place the drone on a straight surface where it can take off.
With both devices turned on, open the "DJI Fly" app on your phone and wait for your drone to connect, you can tell because the app will show you a live image of your Drone.
Now when the drone is connected to the remote control, you can make it go up by pressing the "start" button in the app.
Have fun flying!
Work through the steps in reverse order to repack your drone.
2 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
