Введение
This guide will show you how to replace a DJI Mavic Mini propeller. Damaged propellers are common, as they may be damaged in flight. This guide provides a simplistic and easy to follow instructions on replacing a damaged or faulty DJI Mavic Mini propeller.
Make sure to have extra propellers. If you purchased a DJI Mavic Mini, it should have come with extra propellers.
Have extra screws only if needed, as some screws may be damaged.
You need a maximum of 8 propellers, as that is how many propellers are on the drone, although you only need the quantity that you are planning to replace.
Make sure the drone is compacted before starting the process, as this may help prevent accidentally breaking the drone arms.
Выберете то, что вам нужно
Double check if your propellers are on properly.
Check for any loose screws or propellers.
Gently pull on the new propellers you had just replaced.
Gently move your Mavic Mini drone around, rotate it a couple of times to indicate any loose parts.
Do one last check to make sure the propellers are on their proper sides.
Do one last check for any loose screws or propellers.
After this guide, you’ll be able to replace your DJI Mavic Mini propellers easily.
Еще один человек закончил это руководство.
