Введение
Is your DJI Mavic Mini experiencing trouble with its propellers spinning or unstable flight? Many of these problems can be due to debris build up/obstructions, or improper fitting of the propellers. In this set of instructions, we will detail the removal process, inspection, and replacement of the DJI Mavic Mini Propellers.
Выберете то, что вам нужно
Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
For ease of access place the prop arms in the "open" position.
Remove the 2.4 mm J000 screw from the damaged propeller.
Remove the damaged propellers.
