DJI Mavic Pro Front Vision Replacement
Выберете то, что вам нужно
  1. DJI Mavic Pro Front Vision Replacement, Battery: шаг 1, изображение 1 из 3 DJI Mavic Pro Front Vision Replacement, Battery: шаг 1, изображение 2 из 3 DJI Mavic Pro Front Vision Replacement, Battery: шаг 1, изображение 3 из 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Front Vision Replacement, Upper Shell: шаг 2, изображение 1 из 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Front Vision Replacement: шаг 3, изображение 1 из 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Front Vision Replacement: шаг 4, изображение 1 из 1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Front Vision Replacement: шаг 5, изображение 1 из 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Front Vision Replacement: шаг 6, изображение 1 из 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Front Vision Replacement: шаг 7, изображение 1 из 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro Front Vision Replacement, Gimbal/Camera: шаг 8, изображение 1 из 1
    • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
  9. DJI Mavic Pro Front Vision Replacement: шаг 9, изображение 1 из 1
    • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
  10. DJI Mavic Pro Front Vision Replacement: шаг 10, изображение 1 из 2 DJI Mavic Pro Front Vision Replacement: шаг 10, изображение 2 из 2
    • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
    • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
  11. DJI Mavic Pro Front Vision Replacement: шаг 11, изображение 1 из 1
    • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
  12. DJI Mavic Pro Front Vision Replacement: шаг 12, изображение 1 из 2 DJI Mavic Pro Front Vision Replacement: шаг 12, изображение 2 из 2
    • Flip the DJI Mavic Pro over.
    • Gently press the latch for the Gimbal cover.
    • Pull the cover off.
  13. DJI Mavic Pro Front Vision Replacement: шаг 13, изображение 1 из 2 DJI Mavic Pro Front Vision Replacement: шаг 13, изображение 2 из 2
    • Flip the DJI Mavic Pro back over, with its top side facing up.
    • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
  14. DJI Mavic Pro Front Vision Replacement: шаг 14, изображение 1 из 1
    • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
  15. DJI Mavic Pro Front Vision Replacement: шаг 15, изображение 1 из 1
    • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
    • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
  16. DJI Mavic Pro Front Vision Replacement: шаг 16, изображение 1 из 1
    • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
    • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
  17. DJI Mavic Pro Front Vision Replacement: шаг 17, изображение 1 из 2 DJI Mavic Pro Front Vision Replacement: шаг 17, изображение 2 из 2
    • Flip the DJI Mavic Pro over, with the camera facing you.
    • Gently pull the gimbal/camera assembly up and out.
  18. DJI Mavic Pro Front Vision Replacement, Front Vision: шаг 18, изображение 1 из 1
    • Remove the two 6mm JIS #0 screws by turning counterclockwise.
  19. DJI Mavic Pro Front Vision Replacement: шаг 19, изображение 1 из 1
    • Remove the front vision piece by pulling the piece up and away from the drone body.
Заключение
7 участников успешно повторили данное руководство.
Kyle Kelser
Участник с: 10/08/18
592 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S17-G3, White Fall 2018 Участник Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 членов
Автор 14 руководств
Один комментарий
What error codes did you get before having to replace this front cameras?
Daniel Rubio Rocamora - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 41
За всё время: 6,639
