DJI Mavic Pro GPS Module Replacement
Выберете то, что вам нужно
  1. DJI Mavic Pro GPS Module Replacement, Battery: шаг 1, изображение 1 из 3 DJI Mavic Pro GPS Module Replacement, Battery: шаг 1, изображение 2 из 3 DJI Mavic Pro GPS Module Replacement, Battery: шаг 1, изображение 3 из 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro GPS Module Replacement, Upper Shell: шаг 2, изображение 1 из 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro GPS Module Replacement: шаг 3, изображение 1 из 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro GPS Module Replacement: шаг 4, изображение 1 из 1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro GPS Module Replacement: шаг 5, изображение 1 из 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro GPS Module Replacement: шаг 6, изображение 1 из 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro GPS Module Replacement: шаг 7, изображение 1 из 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro GPS Module Replacement, GPS Module: шаг 8, изображение 1 из 1
    • Flip the upper shell over so the metallic plate is facing up.
    • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
    • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
  9. DJI Mavic Pro GPS Module Replacement: шаг 9, изображение 1 из 1
    • Pry the metallic plate up from the upper shell by using a nylon spudger.
    • Remove the metallic plate from the upper shell by lifting the plate up and out.
    • You may hear a popping sound when prying the metallic plate, but no damage will occur.
  10. DJI Mavic Pro GPS Module Replacement: шаг 10, изображение 1 из 1
    • Use tweezers to remove the GPS Module from the upper shell.
Заключение
8 участников успешно повторили данное руководство.
Kyle Kelser
Участник с: 10/08/18
592 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S17-G3, White Fall 2018 Участник Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 19
За последние 30 дней: 60
За всё время: 8,668
