Введение
This set of instructions will walk you through how to replace the DJI Mavic Pro WiFi Board. The WiFi board is located under the upper shell of the drone. In order to get to the WiFi board you will need to remove the battery and upper shell first. You will need to carefully pry the upper shell off to perform this guide.
Выберете то, что вам нужно
Grab both sides of the battery.
Pinch the releasing buttons on both sides of the battery.
Lift the battery up and out.
Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
Flip the drone over so that the gimbal is facing up.
Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
Remove the two small panel pieces near the gimbal case with the tweezers.
BEWARE! The two screws under the covers are not mentioned in step four to be removed, but they show that they have been removed in step five.
Step five should read- Remove the SIX 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
What he said!! ^^^
You might notice that there are two crosshead screws with larger heads (top two circled in image). You do NOT need to touch these as they are not part of the gimbal assembly.
Agree with @elfa1 - do not remove the top two screws, or you will put unnecessary strain on the plastic while moving arms. No need for that at all.
Flip the drone back over so the upper shell is facing up.
Pry off the upper shell with a nylon spudger.
using pry tool is not necessary - once all top shell screws are removed you should be able to take the top shell off with your hand.
Zudem fehlt hier die Angabe der genauen Lage von beiden vorderen Nasen:
Sie befinden sich von der Mitte aus gemessen jeweils 9mm nach links und rechts. Der obere Gehäuseteil wird von zwei 5mm breiten Bügeln gehalten, die unter die horizontal nach innen zeigenden Nasen vom unteren Gehäuseteil greifen.
Sorry “KopaZ Maymay”, but the plastic opener is “so necessary” because otherwise you unfortunately risk the two plastic noses in the front.
In addition, the exact position of both front noses is missing in the description:
They are measured 9mm from the center to the left and right. The upper part of the housing is held by two 5mm wide brackets that grip under the noses pointing horizontally inwards from the lower part of the housing.
Hi, is it a simple replacement. Ie you do not have to reprogram? Thanks
Remove the white connector at the back of the flight controller board by gently pulling at the base.
Hello there, can anyone tell me, please, what type of connector is this? I ruined mine and i like to fixit.
Remove the lone 4mm Phillips #00 screw holding the WiFi board in place by turning the screwdriver counterclockwise.
Remove the two gold coaxial connectors by pulling gently at the base with tweezers.
2 участников успешно повторили данное руководство.
3 Комментариев
Are there any connectivity issues, like new passwords etc?
Mine was removed by the former owner and the coaxial connectors were removed at the same time. I bought a new module that has the coaxial wires and one ribbon cable and now I have to see about removing either the bottom of the drone or one of the boards to gain access to where these connectors go to. Is there another video as to how to do that? Several of the hex screws are stripped to the point where my 5mm hex screwdriver don't remove them. Is there a fix for that (stripped screws)?
'lamao
Max Poerner - Ответить
