Введение
No tools are required to remove the battery from your DJI Phantom 2 Vision+. You should always remove the battery before servicing your Phantom to avoid electric shock or accidentally powering the propellors.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
3 человек успешно провели ремонт по этому руководству.
