Введение
Use this guide to replace an Electronic Speed Controller (ESC) in your DJI Phantom Drone 2 Vision+. The ESC receives power from the central board, and a PWM control signal from the flight controller. There is one ESC for each motor, for a total of four. Removing an ESC requires soldering.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
Выберете то, что вам нужно
Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
Determine if the propellor is clockwise or counter-clockwise rotating.
If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
Remove the propellor.
Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
Remove the following screws from the underside of the Phantom:
Twelve 2.0 mm hex bolts
Four Phillips #00 screws
The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
Pull the GPS connector straight up out of its socket.
Lift the top shell case up and remove it from the body of the Phantom.
Cut the zip-tie securing the signal and power cables.
Unplug the ESC signal cable molex connector from the ESC.
Desolder the ESC ground and voltage wires from the mainboard.
Be sure to plug these cables back in before reassembling your Phantom 2.
Remove the two ESC securing screws.
The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger.
With the ESC no longer secured to the airframe, lift it up and remove it.
8 участников успешно повторили данное руководство.
Один комментарий
Is it a difference between ESC from different versions (1.0, 2.0 and 3.0) of Phantom 2?
