Введение
This guide will outline the steps required to replace the landing gear on the DJI Phantom 3 Advanced. This includes unscrewing the landing gear as well as removing the receiver antenna from the gear in order to replace the gear.
Выберете то, что вам нужно
With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
Turn the phantom upside down.
Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
7 участников успешно повторили данное руководство.
