Введение
If the motors are intact but not starting, then there is a problem with the electronic speed controller. Use this guide to replace your damaged electronic speed controller.
Выберете то, что вам нужно
Use your finger tips to pinch the damaged propeller.
Twist the propeller counterclockwise and pull up to remove.
Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
Flip the drone on its back
Remove the eight 4.5 mm hex screws by turning them counterclockwise with a 1.5 mm hex bit.
Separate the mesh from the drone by pulling up gently and rocking left to right.
Remove two 1.2mm screws using the JIS #000 bit from the camera cable retaining bracket.
Remove the two 1.2 mm screws using a JIS #000 bit from the antenna retaining bracket.
Pull the four U.FL antennae up.
Remove the two 4 mm screws using a JIS #000 bit.
Press the connector tabs with a spudger and pull on the wire simultaneously.
Remove the shell from the rest of the drone.
Remove the two 4 mm screws using the JIS #000 bit.
Flip the metal bracket to the right and slide up.
Desolder the motor and LED wires on both sides of the board. For general soldering information, visit this Soldering Technique Guide.
2 участников успешно повторили данное руководство.
