Выберете то, что вам нужно
Remove the four screws with a Torx T8 screwdriver to access the back con board.
With tweezers, gently remove the large con board tab.
Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
Peel off the rubber grips to access the screw holes.
Remove the back board and set it aside.
Pull apart the back plastic panel.
Once the back panel is off, you will have access to the motherboard.
Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
